Hello i recently purchased a silver 92 in immaculate condition, the only problem is when it is first started COLD it has no power and stumbles and falls like 2 cylinders are dead CEL is ON. once it is warmed up the idle clears up it runs smooth and responsive and the CEL goes out. i have owned many SHOs but i have never had one act like this. any ideas??
i ran the paper clip test and with the KOER i got
111 System Checks ok
i then ran it with the KOEO and got
211 Ignition PIP signal was erratic or missing – Ignition Systems
215 Primary circuit failure – ignition coil 1 – Ignition Systems
216 Primary circuit failure – ignition coil 2 – Ignition Systems
542 Fuel pump open, bad ground or always on – - Power / Fuel Pump Circuits
i would like to mention after doing the KOER test it stalled, i then restarted it and had a hard time, i had to WOT and crank to get it to fire so i wonder if this caused a few of the codes? i was leaning towards a stuck open EGR valve but i would really like your opinions as i am not to familiar with mechanical issues and these cars i had good luck with most of mine in the past.
any and all info is greatly appreciated
thanks
Joe
thanks
Joe
