92 Brake upgrade options
ant-live
Durham, NC
Hey, i've been doing a lot of reading on the forum on brake upgrades. I currently have a 92 w/OEM sized cross-drilled and slotted rotors. What are some options for upgrading the brakes withouth going to the Gen III setup and changing knuckles and etc?
K-Dawg
Treasure Coast, FL
Two options with the knuckles you have:
Stick with the rotors and calipers you have, and get a set of nice pads such as Carbotech Bobcats, Hawk HPS, etc.
or
If Baer still offers it, there is a 12.5" Baer upgrade that uses the 89-93 knuckles.
revhardSHO
Seattle, WA
Trust me you'll want to upgrade to 94/95 knuckles. From there do the 96 upgrade, its very simple and quite cheap.
DemonNeno
SHOCAGO Freak
Skokie, IL
TCE uses the pre-94 spindles for their brake kits. For rear brake upgrades, look no further than the gen 1 style vained rear rotors. TCE kits begin at $1400 i believe, which are 12.2" and should fit under the slicers. This would be a 4 piston setup which includes knuckles, rotors, longer studs, hub & bearing assembly. I believe it's roughly an additional $250 for 6 piston calipers. Add $60 or something like that for directional vaned rotors for the street kit. Road race kit (12.2 x 1.10 rather than the 12.2 x .81 street version rotors) requires aftermarket wheels due to wheel clearance from the wider rotors & larger diameter (13", as would the 13" street kit, though). Core is $200, but i'm unaware whether that's included or not in the price. Please correct me if i'm wrong.
Hope this helps!
ant-live
Durham, NC
Thanks, that does help. I currently have 17 wheels, so i can go to a bigger setup. But i don't have a lot of money to put into it right now. So i wanted to go with something cost effective and still get a better affect.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You should go to the junk yard and pull the knuckles from a 94-95. I think they cost like less then $100 for the pair. Then you can either get a 96 or 13" upgrade. I found a 13" kit at DiskbrakesRUs for under $500. Might want to look into it.
