914-SHO Power wire gauges
3d914
The EVTM does not indicate the gauge of wire used in various cases. I'm trying to complete the power distribution & charging circuits for the SHO bench test. Here are the wires I need gauge thickness for:
  • Red wire from batt + to 12 ga fuseable links
  • BK/O wire after fuseable links to starter/solenoid
  • Wire leading to the power side of the Engine Comp Fuse box
TIA
factory wiring diagram has wire gauges
R from B+ to fusable links is 6 ga.
bk/o after fusable links to start solenoid is hard to find, I think its 10 ga.
wire to power side of power distribution box is a pair of 12 ga. in parallel.
Satchmoz
