91 rear calipers fit 95?
ManySHOs
South Jersey
buechine said:
Will the 90-91 SHO rear calipers fit a 95 SHO?
Thanks
No, not unless you swap the backing plate from the 90-91 over to the 95 along with the rotors, pads and caliper brackets.
Which is actually not a bad idea. I run the earlier vented rotors on my 93. However, the short answer to your question is: NO.
Ian
operdot
USA
what ^he^ said accept if you do decide to swap over the whole wheel hub over be prepared to drop the shocks as the pinch bolts tend to like rust a LOT, both of mine were frozen shut when i did this a couple month ago.
Satchmoz
