91 Mocha in MD
KSL91
1991, Mocha, Black Leather. 140K, new clutch, timing belt, water pump @115K. Needs paint, shifter (cable shifter), plug wires (new spark plugs included), Struts. Has 2-1/2" Exhaust with a single Magnaflow muffler. Tires good condition. Has rust around wheel wells, lower doors. Interior fair condition with drivers seat worn and power adjustment needs repaired. Everything is there. Good for restore or parts. $750 OBO. Email for photos. "[email protected]".
KSL91
91 Mocha in MD, More info
Additional Info.
I am the original owner.
Mobil 1 Synthetic since 3K.
Crank Sensor was replaced along with timing belt, water pump.
When the clutch was done the tranny was drained and filled with synthetic although I don't remember what brand.
There is oil in the plug wells and the spark plug wires are original. It will miss at higher rev's sometimes. It has never had a valve adjustment so it still has the original gaskets.
I have also replaced the fuel pump @ 130K as well as replaced the radiator and CV joints.
The struts are shot on all four corners and probably the bushings as well.
All four tires are in good shape. They are the NTB brand tire (not V rated)and have less than 20K on them.
KSL91
More Photos
http://i673.photobucket.com/albums/vv99/KSL91/91SHO2.jpg[/IMG][/IMG]
JRA2000TL
The Complainer
Daphne, AL
Yep that HAS to be the most rare color combo, probably alot fewer than the green/mocha 91+. Some on here didn't know this color combo existed, and I've seen only a few like this. This is the ONLY car that mocha color looks good on, especially with the black interior. Good luck with the sale. Someone needs to buy this, paint it, and fix it up.
KSL91
The best thing about the mocha color is that it matched the color that the Maryland State Police used on there Taurus patrol cars up untill the mid 90's. On a few occasions, I flew past a trooper running radar and they would just wave. Even had a left lane slow poke pull over for me once as I came up on him.
I'll have some additional pictures tommorrow evening.
KSL91
Added some photos showing the rust spots. The driver side trim under the door has some rot underneath it. The trim is actually attached using epoxy as the fastners had rusted away. Added a photo of under the hood as well.
I live in Riva, MD. Just south of Annapolis.
