90 sho loose tail lamp
daveoshogun
arizona
Hay ya all
I've got a loose tail lamp lenz is there a part # for the gasket or another way to reseal and secure the lenz befor I start swaring because I lost it. all so I need a right lenz mine got crushed this is how my left go loosened. please help DDO
AREA 91
PA SHO SHOP
Area 91
I suppose that you could use some clear silicone to seal up the lens.
Cobraii976
I am an idiot
Well it's a 90 so you could just hit the boneyard and grab a set of SLO tailights. Then again if it was a Gen II you could do the same thing.
SHO_Driver
Montreal, QC
I used some windsheild urethane, holding fine 3 years later. I removed the lens completely, cleaned the surfaces and applied the sealant.
