SHOGUY,
Just to add a little to what Steve has said, if you had a "faulty ground" you would not be blowing fuses, because you would not have a complete circuit without a "ground".
If the "hot" or "load" or + side gets "grounded", say from a wire that has been rubbed through its insulation against metal, the massive flow of current will blow the fuse when the fuse's limit is reached.
The other possibility is a fan motor that is not turning freely and drawing more and more current in an effort to get going, until the amount of current being drawn reaches the fuse's limit.
So, look in the fan motor curcuit, including the motor, switch, and any "hot" lines in the circuit.
I would look at the motor first. They get gummed up, or the bearings get dry, or the brushes get worn out and/or grounded, and are a common cause of the problem you describe.
The switch would be next on my list. If the above are not the problem, then you start chasings wires for a grounded hot wire.
The above is not in the best of electrical terms. I'll leave that for SHOZ123 or a few of our other electrical pros. rangerj
