89 SHO Engine Problems
89SHO X2
Wa
K, My car ran great for a while and started hesitating on acceleration(jump, jump, jump) then it would open up and be fine. It has been intermintent even acts up at full throttle sometimes. Sometimes it runs fine. Have another car I just got it has a good engine. So I swaped the coilpack and maf sensor and DIS out of it. It still ran the same. Now it fire and runs for a few and dies. When I hit the throttle it has a dead spot and dies trying to open it up. It pops also when it is opened up. It was running fairly good yesterday now not so good. What is the most likely cause. Don't want to waste time pulling what I really may not need.:)
I have a cold air intake, with flow meter housing removed, Magnaflow exhaust , and a JET Chip. It ran like this before the Chip and flow meter tinkering.:wave:
89SHO X2
Wa
Thanks, thought so but I ran a pressure test on it the other day and it held at 30-38 on acceleration
89SHO X2
Wa
It may be. started it idles up smooth and drops to about 950 for a few then struggles to stay running then dies. I can also start it and rev. it up smoothly then it bogs down and dies. Fuel pump can be heard when the key is turned on it is kinda loud and very noticable. Preassure a week ago was 30 at idle no varyation and 38 at higher rpms.
89SHO X2
Wa
Check engine light has been on since I bought the car last summer. I have messed with the car and had it running like a top for a long time then it started cutting out here and there on accel. and slowly got worse and then kind of went away but now this.
SHO_DOODmorrris
Owner & Fanatic
Alberta
yeha i bet o2s... quick change. go to the JY and grap a couple or go buy one from your parts store and swapem out.
89SHO X2
Wa
Thanks for all your guy's input. I swaped out MAF with my other car and has no more problems. Ran code and came up with code:66 MAF voltage below minimum.
