'89 mtx is giving me some troubles
al010101
oregon
Ok i'm moving and need to sell this '89 mtx, But it blows coolant out the overflow, mechanics and common sense told me a stuck closed thermostat, so i took it out, but can't afford a new one i cut the restriction out of the thermostat, so that i could keep the little gasket in there, and put it back together, but it's still doing it lightly, so i'm figuring a bad radiator cap, anyone else have some thoughts? or should i just sell it as-is for 400$ and walk away?
SHO#7
Cincinnati
That could be a bad thing. I would say that if the coolant starts to rise in the overflow once the engine is warm, then start with a radiator cap. If it is instant, then it almost sounds as if you may have a head gasket failure.
