80mm MAF
Siman
Location Location
i did a search for 80mm maf but i found random stuff... sho source has it listed for the gen 1/2 only can it work with our V8s and a SCT tuner?
SHO U UP
SHO Guru
Virginia Beach, VA
All V-8 SHOs have the 80mm MAF. Some have plastic housings, others have aluminum. IIRC, the Gen 1/2s has a 55mm and folks would upgrade to a 73mm from C&L. Hope this helps bro.:sun:
Siman
Location Location
well we are going to run the intake to the fender like in trains SHO and we are doing small stuff to it cams should be welded by the end of today found a guy here that can do them. once hes done with them exhaust then the engine will probably be dropped and cleaned and a 5 speed added then suspension. The guy before only welded the back 2 cams i dont know why he didnt do all 4.
rick-ng
Rickybobby
Dallas
How do you fool the ECU from limiting the rev? (selector switch not in drive)
Siman
Location Location
its in the wiering and you can flash the ecu aswell. so no lights pop ip i beleave im still pokeing around on the tranny stuff its a bit of a ways out from the swich so im trying to do as much research as i can ill be doing it in a few months.
