80 mm maf
Lupo
Huntington Beach, CA
The 93-95 Lincoln 80mm, and the 99-00 Lightning 80mm share the same physical housing, but the Lightning MAF has a signal curve pegs at a much higher airflow than the lincoln.
Anyone wanted to go over 400chp would do well to choose the lightning.
The lightning also has a different connector, so you need an adapter, or you need to splice your stock harness.
SHO U UP
SHO Guru
Virginia Beach, VA
Mustangs with 4.6L also have the 80mm, along with the F-150 4.6L trucks and Expeditions.
blckstng96
new jersey
make sure its not 03-04 lightning bc thats a 90mm,huge.i have one on my mustang but the stock one on my 4.6 was an 80mm.if anyone wants to buy it i have it still
Axianator
I am a banana!
Roanoke, TX
anyone have the list of cars that came with this?
If you're referring to the 80mm MAF from the '93-'95 Lincoln Mark VIII, that MAF was unique to the Mark VIII.
If you're referring to the 80mm MAF from the '96-'99 V8 SHO, here is an application list:
SHObill
'The Collector'
Rochester MI-48307Detroit
I bought a LPM for my 95ATX programed with tranny upgrades BUT it also is programed for an 80MAF. I don't really want to add an 80MAF but was told I had to, to use this LPM. BUT now the electronics on the 80 do not match my harness! & I do not have an adapter to fit the stock airbox! So do I have a Lightning MAF?? Did only the Mark8 plug into our harness?
It would be interesting to compare the different MAF tables to those different vehicles using the same MAF.
Axianator
I am a banana!
Roanoke, TX
I agree, and if I had copies of the PCM images from those vehicles and their related clock speeds, I could extract the MAF transfer functions from each within a few hours.
