boat
Likes blue ones
We have Bubba's wife's 93 ATX, that Bubba and I have been working on little by little for the last year and a half. It sat for like 7 years before we picked it up, it has now sat for another year or so. Mainly due to life happening and both of us having a lot on our plates to get this done. A lot of little things have been replaced also. Headlights, tail lights, power window motors, got rid of an electrical drain and a busted off egr tube at the manifold.
Well anyway, trying to get it finished so his wife can finally have it. We have replaced nearly every suspension component except sway bars on the car. Did a full black leather interior swap from mocha. Now we are coming down to some final tings to be finished.
The oil cooler gasket is leaking and I plan on changing this tomorrow with a low mileage one we have in the garage. I was thinking while changing that, I would flush out the radiator from the over 8 year old antifreeze that is in there. Well, we don't exactly have access to a hose in the garage and it is too cold to be messing with hose water any way.
My idea to flush the radiator out would be to pour through the radiator about 3-4 gallons of distilled water collecting it out the drain valve out the bottom. Would this do a good enough job to clean out the old gunk from years of sitting?
Any other recommendations for flushing it out. Right now the car isn't drive-able, a rear brake line busted on it and has to be replaced.
Also, I suspect the oil is pretty old too, not sure how old, but yeah. Would it be sufficient to do a standard oil change or should I pour a thinner oil through, or a couple of quarts of cheapo oil to get as much of the old out as possible?
