632 KOER code?
zblackbeast
SHOtarded
Omaha, NE
632 (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
no idea what that means. but thats the code
hawkeye18
Sorta cares
Norfolk, VA
yeah, that code means the ECU didn't see you cycle the O/D switch when it expected you to. You have to do it virtually at the same time as you goose the throttle, apply the brake, and turn the steering wheel in both directions. Don't worry, you won't confuse the ECU.
If O/D works in your car, and the O/D button works in your car (i.e. hitting it will make it shift into 3rd), don't worry about it. You either did it at the wrong time or the computer's ********.
benjammin
washington st.
so that code doesnt have anything to do with the high pitched howling sound my tranny makes when its warm?...BTW, Thanks for the input.
