naval-avi8or
When you do the valve shims do you have to tear the lower/front of the motor apart ie. do you have to take anything loose such as the crank pully and timingbelt, or is there a way to turn the cams without touching the front. What I'm trying to do is gap the valves and then order the shims I need verses ordering 100-200 dollars of shims hoping to get what I may need.
