Does Gates T248 has marks, whitch belt is the best? Fel-pro #VS50378R gaskets from RockAuto is everything what I need? Spark plugs holes are full of oil.
The gates T248 does have the marks to properly set the belt. THe VS 50378R gasket set is the valve cover gaskets and the plug well seals. I'm not sure exactly what else you are asking though.
Here is a list of the more common parts that are replaced during the 60K/100K services and the mileage intervals for their periodic attention. Take a look at the list, your engine and your car's service records to determine what you should consider replacing.
