60k tuneup
Polar Pear 2004
rossford
What do i need to do this. shoot
Photo Page
<small>[ July 16, 2002, 06:06 PM: Message edited by: Polar Pear 2004 ]</small>
Machspeed
Former 1991+ owner
Santa Barbara, CA
Heres an email from nick chrimes to me:
Basic 60K:
Scan for Engine Diagnostics
Check under car for problems
Replace parts listed below
Adjust Valve Clearances
Check EGR passages and Throttle Body, clean as necessary
Perform Test Drive
Item
V6 MTX Timing Belt E9DZ-6268-A $53.29
V6 MTX Power Steering/water pump belt JK4-506 E9DZ-8620-E $21.91
V6 MTX 89-93 Alternator/AC belt JK6-450 E9DZ-8620-D $26.20
V6 Thermostat RT 1112 E9DZ-8575-B $26.08
V6 Gauge Temperature Sending Unit SW 2328 F1SZ-10884-A $8.18
V6 Front crank seal E9DZ-6700-B $7.20
V6 Fuel Filter FG-800A $10.70
V6 ATX Upper gasket set F3DZ-6079-C $147.28
For a 120K service, consider adding the following:
>From SHO NUT Performance:
V6 MTX Water pump PW-272 F0DZ-8501-A $200.00
V6 MTX Upper Rad hose KM-3084 F5DZ-8260-FA $31.30
V6 MTX Lower Rad hose KM-3086 F5DZ-8286-FA $24.12
V6 Coolant hose 1, U-tube, KM-1719 E9DZ-8548-A $11.62
V6 Coolant hose 2, cooler to therm., KM-1720 E9DZ-8548-B $21.88
V6 Coolant hose 6, TB to engine, KM-1721 E9DZ-8548-C $8.02
V6 Coolant hose 7, IAB to engine, KM-1722 E9DZ-8548-D $7.76
V6 Coolant hose 8, TB to IAB, KM-1723 E9DZ-8548-E $7.92
V6 Timing chain tensioner, RH (special order) E9DZ-6K261-A $96.45
107.17
V6 Timing chain tensioner, LH (special order) E9DZ-6K261-B $44.84
V6 MTX O2 Sensor DY-606(2) F0SZ-9F472-A $103.50 F3DZ-6C315-AA $109.50
Just a little list...
<small>[ July 16, 2002, 07:04 PM: Message edited by: FOR SHO ]</small>
