60k, should i expect any perf. gain?
Machspeed
Former 1991+ owner
Santa Barbara, CA
Im about to have nick chrimes do a 60k mile service for me, i was wondering how much, if any performance ill gain. The only parts ive changed are the 02 sensors and the fuel pump and filter. Im also gonna do a decarbon procedure. Thoughts?
N3FOL
Pennsylvania
I am currently in the process of doing my 60K maintenance (timing belt,CPS,water pump,thermostat, temp.send unit, plugs, wires, new shims, gaskets, 02 sensors (done already), main oil seal, hoses, etc..) as we speak. I have owned my 1995 ATX since brand new and I am a rookie on all of this. Halfway through the job...so far. Trust me, any type of maintenance to your SHO will definitely benefit her and your pocket book in the long run.
Go for the maintenance routine and you'll be glad you did it.
wink Wish me luck along the way.
nc89sho
S13 Sellout
Clemmons NC
you should notice that the car runns alot smoother and getts better gas mileage. i also noticed after mine that the car had more consistent power throughout the rpm range.
It's not so much a performance gain as a restoration of the original power than has been lost due to stretched timing belt, overly large plug gaps, leaking spark plug wires, slow oxygen sensors, etc.
Machspeed
Former 1991+ owner
Santa Barbara, CA
sdpatt:
Very true, i guess its restoring lost power...
Axianator
I am a banana!
Roanoke, TX
FOR SHO:
That it is.
After sdpatt performed the 60k/100k on my '95 ATX, my engine ran both a lot stronger and a lot tighter. There was a noticeable difference in the before and after (to me, anyways).
<small>[ July 14, 2002, 10:27 PM: Message edited by: Axianator ]</small>
Satchmoz
