Troj84
Did my 60K a few weekends ago. A problem has developed after about 300 miles. My car is leaking coolant from the front of the engine. Im sure its the waterpump. I put a new motorcraft one on when I did the 60K. I think it is leaking near the area where the pipe that runs across the top of the engine slides into the waterpump housing. The O-ring is the only seal. Is there any special trick to getting this right? I was leary of it when I did it and now of course my worst nightmare is coming true. Is there a way to see if the waterpump is leaking itself? Also when I took my belts off, after releasing the tensioners, I could not hardly get the belts off. I literally had to pry them off the pulleys. I had them replaced a few years back and wonder if maybe they put the wrong ones on. I had to loosen the alternator to get one off. I just didnt think it was that tough to get them removed, and of course putting them on was tough as well. Lastly, what trick is used to get the crank pully bolt torqued to its spec. The engine moves prior to getting the required spec. THanks for your help in advance. I love my SHO, but having to tear down to fix the waterpump has me very dissapointed. Time to put the car in the garage for the winter.
