60k? Maybe half of it done
sho4life
midwest
Well i just tool off the timing cover to find a napa timing belt, good news . Then i noticed that the water pump had the stamp made in polland??. Doesnt seem right to me. I checked a reman unit and had nothing stamp on it where it was made. Im hoping that the person decided to change the cps at that time too. How important is it to get the valve adjusted on a 130k engine? Lots of oil in the plug wells so im buying new seals plus rod bearings should be good to go the engine wise. Just need to sell my z24 now to get the wavetrac. All new hoses too. what else should i do?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I would do the valves when you to the valve cover gasket. I have done SHOs that needed only shim to over half needing to be adjusted. You just never know.
shobroooo
