60K in Milwaukee
95ATX/Milwaukee
Milwaukee
Is There Anybody Local In Milwaukee Or The Surrounding Area That Is "qualified" And Willing To Do A 60k For Cash. You Must Have Experience And A Place To Do It. Miltown Of Shoforum Can Be Used As A Reference To Attest Cash Money Paud For Good Work. I Would Like To Do This After Christmas. Contact Mike At 414-763-2896
Thanks Guys And Gals.
Mike
jbserra
Greenfield, WI
I've done a '92 MTX and plan to do my '95 MTX over the week just after Christmas. I might be interested. Am I qualified enough or are you looking for a certified mechanic? What items are you looking to do? It's funny. I just came on here to start gathering the stuff I need for my 60k. Let me know.
I'm in Menomonee Falls.
95ATX/Milwaukee
Milwaukee
60k
Hi, The valves are LOUD, and my auto tensioner pulley needs replacing, as well as the power steering pump. You do not have to be a certified mechanic, but I would expect you to have the proper tools for valve lash adjustment, etc. My biggest worry is I do not have time to bring a car back to you for poor work done. If you qualify let me know a ball park range for the work i listed, I will not hold you to any number. Mike
jbserra
Greenfield, WI
Well, I don't think the valve lash, or the auto tensioner pulley replacement would be an issue. I have never done a power steering pump, but I do have the repair manual for the SHO at home. Let me take a look.
I do have garage space, air tools, and the valve shim tools.
Did you call around to see how much a valve lash adjustment would run? I seem to remember a quote for $600-$700 LABOR, and the shims were free :) What a deal! Not to mention, I had to explain to them why I wanted to have this done. The Ford dealer had no clue about the shims in the SHO. Anyway.
I'm guessing $200 for the valve lash & pulley if you provide the parts (we can split the shim kit cost). As I said, I can check on power steering pump replacement. If it is straight forward, $25-$50.
If YOU want to do the work simultaneously to me with my SHO, then just bring some Mountain Dew.
jbserra
Greenfield, WI
Well, it took me 2 weeks to get everything done, and acquire parts along the way, but it's back running.
Let's see, part list:
O2s, Valve cover gasket, plug seals, crank seal, timing belt, throttle body gasket (which I broke), thermostat, one broken valve cover bolt, plugs, plug wires, oil + filter.
Key points:
Cincy's SHO 60k documentation helped with reinstalling crankshaft pulley. Heat it up! Worked great. Also, they showed a way to torque the bolt by putting the car in gear, and using a lug wrench to stop axle rotation. Man, 150ft-lbs is hard to get too!
Mark's 60k video helped with everything else.
All my valves were in spec. Why am I disappointed? Oh wait, I RENTED THE KIT. Well, there's $70 wasted. I'm sure they all would've been messed up if I didn't rent the kit...
You will HATE everything attached at the back of the engine. I cursed the SHO every intake support nut, etc connected to the back. Ok, I love the car again now that it's back together, and running :)
Oh, rotate the engine with a wrench ones you put the crankshaft position sensor back in. Mine was rubbing which I didn't realize until I buttoned almost everything back up. I couldn't gap it right with the flat metal feeler gauge I had, so I just put whatever size in there that wouldn't rub when I rotated the engine. Yeah, that may come back to haunt me. I did notice there was one slight higher spot on the cam gear, so I gapped off of that spot.
I didn't hear from you, so either you're doing it yourself, or you found someone else to help. Either way, good luck, and maintenance is good.
crystizel
