60K Gone wrong
ctm78
Chicago, IL
Okay, so I "completed" the front-end 60K. . .
Everything had been put back together, and when I put he key in the ignition there were a couple clicks/thunks, and then nothing.
When I walked back around the front, I saw several pieces of the lower timing cover underneath the car, including what looks like some type of access panel. (for the tensioner?)
Suffient to say I haven't cracked back into her yet. . .anyone have any ideas as to what I messed up that I may want to specifically look for?
Dr. Tweak
Mad Scientist
Northern Vermont
eep! eek!
Well something wasn't put back together right. The middle timing cover is a little tricky, the left side of it needs to go BEHIND a part of the rear timing cover.
You're just going to have to tear back into it and check it out.
SHOTerror
Orange County, CA
Most likely it isn't starting because you didn't bolt the crossover tube you removed down, this grounds the DIS and will prevent your car from starting if not properly grounded.
