60-100K Service Recommendations??
Ponyexpress46
i have a 94 atx with 100k, second owner,oil changed w/mobil 1 at 3k, car runs great, no problems, im hesitant spending the money, dosent make sense to spend a thousand dollars if im not having car problems.........any advice?
Groo
Glenview, IL
You may not have problems now, but you will once your waterpump starts dripping on your CPS, your crank seal starts leaking, and your timing gets off the mark. It's OK to hold off until you actually notice a problem, but one way or another, you're going to have to fix it eventually.
poffffd
