5th Gear... uh.... studder....
SASHO91
Zoom Zoom
San Antonio,TX
.... thats the best i can give....
i was heading home last night, and went to pass someone, while in 5th, and i get a really quick studder... another way to describe it would be if the clutch was slipping for a short(a tenth of a second at a time)time and catching... but a third gear pull, (as well as 1st and 2nd) said other wise.... Thats what first poped into my head... but repating the studder(going about 1/2 throttle in 5th, @70-75mph) kept me thinking it may be spark/fuel delivery...
To almost rule out the possiblity of it being the clutch, I slipped the clutch off the line, and pulled to 40... then stopped again, and launched the car... no slippage... ( i know i slipped the clutch.. i know what that smells like.. :doh: )
So, could the problem be in the A/F department? OR the Spark store... ?
i pulled an all nighter... and dont want to search this morning... zzzzz zzzzz :rolleyes:
TIA.
SASHO91
Zoom Zoom
San Antonio,TX
I guess i'll try to throw some new plugs in... not too sure on miles on these plugs... and i have a couple sets just laying there.. :slap: been procrastinating(see below)
by try i mean... i cant get the old ones out.... :doh: tips?? Liquid wrench down on the plug and let set?
SASHO91
Zoom Zoom
San Antonio,TX
i guess i should start with wires first then?
Could the coil pack also be held liable for the syptoms?
twr
whoohoo
half-way there, I think.
Not generally, Either wires or plugs, the spark is looking for the path of least resistance.
DHMag
Free At Last
InCahoots, Texas
that was the problem i was having with the car when i sold it to you. i mentioned this to you at that time. its a misfire. plugs were changed right before you bought it, wires have been on there for a couple years.
SHOblime
State College, PA
What RPM were you at and how much gas did you give it? Sometimes it's better to drop a gear (not trying to be a dick here) and give it a *little* gas..that fifth is an overdrive, it's for economy, not passing people at 75mph
SASHO91
Zoom Zoom
San Antonio,TX
well, it was a miss... and got worse as the day went by. So i swapped out the NGK's, for some bosch supers.. and swapped wires... all is well now.
Dale, that problem was the DIS. I swapped it out... that fixed that.. this was plug/wire oriented...
SHOtimer
#2910
Santa Clarita, Ca
The Bosch supers arn't gonna last very long.
Doug
SASHO91
Zoom Zoom
San Antonio,TX
eh.. i've got a few sets....
what else should i run? The plugs i were running are discontinued... the double plats.
what do NGK's run?
SASHO91
Zoom Zoom
San Antonio,TX
yes, i know.. I wasnt lugging the motor..
2800.. and maybe 1/2 throttle. but thats on level highway... i wont do it going up hills, or the like.. :thumb:
thatSHOguy101
