Assuming your car has not had the upgrade to the rod shifter, it's probably worth taking a look at the cable linkage at the transmission. It does sound likely to be a linkage problem. FWIW, when we did my clutch job, the remaining "piece" of the rubber bushing on the transmission shift bracket fell apart. Didn't take the time to do a replacement as the temps were falling fast and snow was blowing in the garage! However, this bushing does keep the cable from binding when making the shifts. I can feel it with my upward shifts but hasn't caused any grinding. Josh @ Shonut recommended the use of bulk ps hose as the replacement bushing. I've just been too lazy to crawl under there to fix it!
<small>[ January 14, 2004, 02:07 PM: Message edited by: fricker66 ]</small>
