332 Error cause HEGO Lean?
joesho_gb
95 ATX
WI
Would the "infamous 332" ERG valve opening error cause the codes HEGO Lean RH and LH (172 & 167)?
I followed the instructions to pull the codes, and this is what I got.
I just want to ask someone in the know before I go drop $$$ on o2 sensors.
jmpSHO
Massachusetts
I don't think code 332 would cause the codes 172 and 167. I can't remember what code 167 is but 172 is O2 sensor related but sometimes you might have a lean/rich code because something is causing your car to run lean/rich like a bad MAF sensor or vac leak.
joesho_gb
95 ATX
WI
jmpSHO, that's scary. Your SHO looks almost exactly like mine!
Put the front plate on, and yellow the headlights a bit, and it's mine lol!
joesho_gb
95 ATX
WI
has dual cowls up near the wipers that are open.
Bad part, no strut stands. Going to have to get some and JB Weld the suckers in place, tired of using a piece of bent exhaust pipe to hold it open every time I pop the hood.
All a work in progress.
