3 Bar MAP upgrade
Bobrl
Ocala, FL
What are the negative details on upgrade with tuning adding a 3 Bar MAP. Can it be too much boost? Why would my local tuner not want to go with 3 Bar MAP? I want the most I can get for the short burst once in a while... Am I asking for too much? He uses HP tuner. I appreciate any response, TY
76FoMoCo
Nampa, ID
Get a different tuner.
This.
The factory tune is less than the turbos are capable of this why the factory only used a 2 bar. The turbos can not put out more than the motor can take so the 3 bar let's you push the boost to the max the turbos and fuel will take. Gear head has what you would call plug and play best bang for the buck.
Jordan_R
Missouri
Agreed, universal tuners never work out on these cars. Get someone who knows the platform and can actually do you right. Local speed shops aren't really the best at anything anymore other than installing hardware.
Bobrl
Ocala, FL
Ok, any SHO tuners inFlorida?
Majestic
You don't need a local tuner. Look up Gearhead, AJP or several others. You can apparently use a computer/phone, so you can load a tune and install a 3 bar map.
Bobrl
Ocala, FL
Ok, is there a DIY instruction for someone new to this? Maybe a follow instruction-step by step. If a so-called partial tune(wants a intercooler to do more boost, claims HP tuner) be removed if a GH tuner was selected and I do the install. Will it get complicated?
Majestic
Gearhead will give you a step-by-step on how to load a tune. Your tuner is a complete idiot if he is telling you a different intercooler is needed.
Cheesehead
Schofield, WI
Can't agree more with Gearhead, and this was after switching from another well-known company. Fantastic. More power and better gas mileage over the past tune. Drove it for a month with a 2 bar and stock tune from the factory and it was absolutely depressing. Just get the SCT tuner, 3 bar and thermostat and order the tune from Gearhead and you will be happy. And that's just entry level, can't wait to do more!
