O.k. this is getting really old fast, in the last 4,000 miles I have went through 3 NEW Alternators and 3 NEW interstate Batteries.
I took it to the shop as the car Battery light is on and the first thing they do is check the Battery and Alternator.
Then they tell me the Alternator is no good so I go and buy a new one after I just replaced it last fall before I put it up for the winter and they put it in.
The car is doing the same thing when you sit with the air on with out driving the idol will start to slow down and the light comes on within 2-5 mins
I take it back to the shop and they tell me the alternator wire was lose and it should be good. Guess what same thing happens 2-5 mins and light comes on and ac shuts off as the power of the battery is to low.
I then take it back and they put it on and test it and tell me it said change battery terminal so they change that and again same thing happens.
Go back and the alternator is shot and I take it back and get a new one for them to put on. Guess what...... Same thing happens the car losses power with the air on within 5 mins.
I take it back AGAIN and they have no clue. They say the wires are good and the alternator is new and the battery is good so the only thing they can think of is that it has the performance pulley that they keep putting on all of the new alternators so they tell me the stock pulley is smaller and will spin FASTER and that should fix it. So they change the pulley and put a smaller belt on and GUESS WHAT????
The car does the same F***** thing.
$600 later and STILL THE SAME PROBLEM
I WOULD LOVE TO HEAR ANY IDEAS FROM YOU GUYS!!!!!!!!!
Could it be the air doing this??????? It kicks on and off fine and is ice cold could it be the clutches on the A/C?????
