Did you reconnect all your grounds?
Did you reconnect all your vacuum lines?
Three grounds: At negative terminal, at rear passenger intake bracket, and at the two bottom bolts of the DIS (make sure the two bolts that secure the crossover tube to the intake are tight as well).
Vacuums: Big one at the rear of the intake, PCV from TB to VC (won't cause the car to die, but check anyway), from TB to Canister purge solenoid (goes down by the coil pack towards the ground), and of course, every single intake bolt... are they tight? Are all the rubber hose clamps tight? Did any of the rubber hoses crack? Check the bottoms; they can crack in non-obvious places. Also, check the IMRC (butteflies) - is the vacuum canister hooked up on both ends? Is the EGR/DPFE/Solenoid hooked up? Are any of those vacuum lines cracked?
