stick
SHO Addict
I'm in the process of getting an engine for rebuild. If I get it punched 30 over and go from there, what am I looking at ?
Mr Anonymous said:You gotta call around and ask your local machinists. Could be as cheap as a couple hundred, or over a grand, depends on who, what's included beyond the boring, etc., etc., etc.
SHOtimer said:I have just finished this process, in fact I am getting ready to start my 0-mile 3.2 this evening. You can't do just boring. You will want the block tanked,the crank polished, new rings, new bearings, and new freeze plugs, that will be a basic rebuild. As Chris said above a lot of that depends on the machine shop.
Also, with heads, are you going to have any valve work done? That can vary greatly on the amount of work and so forth. I would say for a good quality rebuild you'll be looking close to 1k, varing a few hundred.
Doug
