Off Road SHO
Moderator
The reason they used a spring is to keep a constant tension on the belt during its periods of little slack/ lot of slack. The more times the valve springs are compressed per second, the more tension is put on the belt by the crank sprocket to turn the upper sprockets. As you vary rpm's, the tension is going up and down. The spring keeps the right amount of tension no matter what.
With your set length system, you will just have to keep a constant watch on it, that's all.
Tom
Tom
