3.2 ATX SHO Leak???
1998v8sho
1998v8sho
Haverford, Pennsylvania
Hey guys,
I have a leak coming from the bottom of the radiator (driver's side) Looks like radiator fluid or transmission line leak. Not sure. It is coming from a hose that Ts off. What hose is this and what type of leak is this (radiator or tranny line)?
Thanks in advance for the input and advice!
whiteguy3
Scott MacIntire
Silver Spring, MD
Radiator fluid and transmission fluid are two completely different colors; green vs. red. If it is coming from the bottom of the radiator then it most likely radiator fluid. A typical problem is that the crimped ends of the radiator which attach the two end-tanks to the radiator itself tend to leak over time. Sometimes removing it and crimping them tighter help but it is only a band aid.
