3.0 vs 3.2 heads
VortecGT
Wisconsin
Is there a difference? I thought I heard once that the cam chain tensioners were different? Will they work on a 3.2?
bubba
ATX Connoisseur
Fort Wayne, Indiana
everything is the same! but the cams! are different.....and keeping the 3.2 heads during a 3.2 swap...You have to cut the 3.2 head!
jonheese
Used-To-Know-It-All
Fogelsville, PA
The 3.2L timing belt setup is different from the 3.0L unit, but the chain tensioners are the same. The cam lobe profiles on the intake cams are different (more lift/duration in the 3.0L intake cams). As Bubba mentioned, some minor bits of the outside castings are different.
Other than that, I know of no other differences.
Communication between the intake ports is different.
I'm not sure what you mean by this...
I have a 3.0 and a 3.2 on stands in my garage, and I just went and inspected the intake ports and I can see no differences between them. Here are some pics I just took:
3.2L intake ports
3.0L intake ports
Besides the copious amount of carbon on the 3.0L ports (the engine has almost 300k miles on it), they're practically identical to my eye...
zak
east of Hartford
Jon - Were those late 3.0 heads (94/95)? The side of the opening between the two ports varied, and was larger (IIRC) on the 3.2's. The 3.0's might have adopted this in the final years of (low rate) production.
This might have been done to improve injector spray pattern for emissions reasons, but that is conjecture on my part.
zak
jonheese
Used-To-Know-It-All
Fogelsville, PA
zak
Nope. It's the original head from my '90. The 3.2L is a '93.
AREA 91
PA SHO SHOP
Area 91
The coil pack mounting is different. It's slightly tilted. The intake cams on the 3.2 are smaller.
I have seen no differences between the 3.0 and 3.2 heads as far as the ports and cumbustion chambers.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Aha, that's right, I forgot about that. Although I suppose that might fall under "minor bits of the outside castings". :)
Brett
SHOs before HOs
Minnesnowta
3.2L intake ports
3.0L intake ports
I have 3.2 runners on my 3.0 if there is a difference it didnt affect fitment.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Just to clarify, by "runners", you mean the "snakes" right? I don't think anyone is saying that the runners are different between the 3.0L and 3.2L intakes. After all, you're talking about the intake, not the head, and I think this discussion is about the head differences.
