3.0 vs 3.2 crank pulley???
blownatx95
Minnesho on an alternate user name
cheeseville
are you talking about the crank pully for the accessory belts or the crank sprocket for the timing belt? the timing belt sprocket is the same between the two, the accessory pully/damper is quite different.
