FOMOCOTOSHO
I eat Rice.
So I was talking to Doug Lewis @ FPS today about a few things & my desire for some more low end power & torque on my '95 ATX. He suggested swapping out the intake cams from a 3.0L.
Has anyone else done this? How difficult is this? I've searched a few other threads on changing camshafts but I'm not very clear on EXACTLY what I would need to do or replace to do this. Here's my basic knowledge on what I need to do up to now
1) Remove Intake & Valve Covers
2) Remove Upper Timing Cover
3) Remove Timing Belt & Upper Cam Sprockets for timing belt
4) ???? This is where I am unsure. How do the cams come out? Do you need to pull the timing chain, sprockets, tensioner off on the other side? If so, how do you do that?
5) Are the specs that far off on the 3.0L Cam that the valve shim adjustment would be completely different? Or could I swap the shims?
Any help from someone who has done an actual cam swap (not just replacement) would be helpful if possible.
Thanks!
Thanks!
