2013 lincoln mks ecoboost code p0087
Jimgordon
Ii have a 2013 lincoln mks ecoboost. im told it mechanically identical to a sho. its throwing a check engine light. the code it p0087 low fuel rail. it dose not seem to be running rough. whats going on with it
Must be one of the lucky ones then, with that code! Usually that means the low pressure fuel pump/fuel pump control module and/or the high pressure fuel pump is having issues. Maybe it was enough to set the light but not enough yet to cause a problem. When it does become a problem, you may find yourself stranded anywhere, so best to have it looked at right away.
There IS a recall on some SHOs & MKS's for the LPFP and/or Control Module, so you should check your VIN on this site to see if your MKS is included:
http://owner.lincoln.com/tools/account/maintenance/recalls.html
http://www.revbase.com/BBBMOTOR/TSb/DownloadPdf?id=180118
http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg103957.html#msg103957
Even if it isn't you should have the dealership check it.
Jimgordon
It dose show my car has any open recalls or field service alerts other then an update to the sync system
Have the dealership check the fuel pumps and control module anyway. What is the build date for your MKS?
Jimgordon
The fuel pump was replaced under recall before i bot it i was told
Jimgordon
Cleared the code yesterday. drove around till all the monitors reset and the code has not come back. going to try warm starts all day to try and make it come back on. if not i guess im good
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Same code had ford recall fuel pump module, car runs better now then ever, smoother, quicker, quieter....
