Ii have a 2013 lincoln mks ecoboost. im told it mechanically identical to a sho. its throwing a check engine light. the code it p0087 low fuel rail. it dose not seem to be running rough. whats going on with it
Must be one of the lucky ones then, with that code! Usually that means the low pressure fuel pump/fuel pump control module and/or the high pressure fuel pump is having issues. Maybe it was enough to set the light but not enough yet to cause a problem. When it does become a problem, you may find yourself stranded anywhere, so best to have it looked at right away.
Cleared the code yesterday. drove around till all the monitors reset and the code has not come back. going to try warm starts all day to try and make it come back on. if not i guess im good
