2011 HID Problem
mart
Headlight had a crack. Ballast was shorting out. Replaced entire headlight assembly, bulb, ballast. When I plug the connector into the headlight it comes on. When I turn the car off it will not turn back on. HELP!
mart
This is drivers side. Passenger side works as designed.
xFallenxCripplex
Assuming checked all fuses are both not coming on now? Try getting 12 volts to the ballast to see if it's a bad ballast or car wiring? If you have FORScan and an obd connector to laptop you can see if you can reset modules to fix it.
Sent from my Nexus 6P using Tapatalk
mart
Fuses checked. Is there a relay? What module needs to be reset? Thanks for your help!
mart
To clarify, every time I unplug/plug the light back in it will come on. It will just turn off again when I turn the car off and force me to unplug/plug again.
xFallenxCripplex
Check the dtc for any errors see what that says then the next block down id just reset all modules unless you get a dtc that looks it pertains to your light issue
Might be a bad ground or low battery even
mart
It is an OEM unit. Standard ODBC scan tool shows nothing wrong.
