2010 TPMS Question
Stumps76
Ontario
Hey all. Wondering if anyone can tell me whether I can use these TPMS sensors on our 2010 SHO? I can get them way cheaper than the $86/sensor directly from Ford. Thanks in advance.
Dale
EcoBrick Bob
Clear Lake, IA Naples, Fl
That looks like the type that are in 2010 SHO, FLEX, etc., but sometimes the part number is different. I have purchased TPMS off of ebay that worked just fine. Believe the whole set of 4 cost me under $120. with bands etc. I assume you have a re-set tool. You will need that , or have your installer do it, which some charge big $$$ to do. My other set came from TireRack and I paid more, but they road force balanced the tires, so in the end it cost about the same as if I had everything mounted and RF balanced locally.
Stumps76
Ontario
Thanks. I don't have the tool but will probably pick one up. I just wondered as the part number was different than what I had seen when I searched the Ford parts website. I figured they would work as the seller claims they do and they do show the 315MHz. Can't go wrong for a $100 for all 4.
nynd
Ontario
Looks like the right type - I've got 4 sensors and bands if anyone is looking for them for a 2010 SHO.
EcoBrick Bob
Unless you have non-stock bands, you will need new ones. Stock ones use a simple clip that can't be re-used.
Look for the tool that can re-set the TPMS on e-bay. I paid around $25. - 3 years ago and it is a little white box that has a center button that you aim at the TPMS sensor which you are supposed to position at 180 deg from valve stem... I assume for balance... Once you go thru Ford's "switch and brake steps" that are like being at a dance studio audition...(LOL) it is easier to get a beep out of the horn than it is with GM's TPMS re-set system... ** ** **.. MERRY CHRISTMAS!!!
