Remove the three bolts connecting the cat converter to the turbo, this allows the pipe to drop out of the way of next step.
Access to these is through pass wheel well. These take a ton of torque i had to use a swivel and large braker bar. My impact couldnt touch 2 of them. They came out as studs not nuts.
Go under the car to the rear of engine near firewall and take these three bolts out of the aluminum mount. I did end up taking out the two bolts not pictured that connect this mount to the PTU/transmission. Gear Wrench style hand wrench 13mm helps get these out.
I found out that if i oy did the 3 pictured the mound would hit the turbo oil pipe as it was lifted. I just couldnt get a picture of them. I actually left the one bolt in the steel bracket to turbo mount. No trouble in this area during the pull out.
Out of order, but this is how i broke the cat bolts loose, had to turn wheels left to get enough clearance.
While under the car you have to unbolt a 6mm nut and unhook two connectors on the electric steering rack, these are kindof hard to reach and pinch hard enough to release, but it can be done from the underside best. Once done you can pull this harness up the drivers side by the battery tray. You have to unbolt and disconnect the ground and little black box in the 2nd pic on the rear engine head.
Its part of the wiring that has to come up the drivers side from the steering rack.
Remove plastic flywheel access cover
Two plastic screws.
ROTATE engine with screw driver through starter hole.
Remove each of the three torque converter bolts.
I used the screw driver jammed in between flywheel and TC to hold it whole i unbolted the TC bolts. This is a real gread design super access!!
Now unbolt the front Cat from the front Turbo, you have to take the oxygen sensor off to get a bolts.
Unplug Any oxygen sensors I didnt detail
AFTER this check for anything still connected I may not have detailed.
Last post will detail final pull procedure
