2010 ABS UNIT
google the part number and see what pops up. I can't say any seller is good or bad but options will pop up. I would look at used part locator sites like car-part.com that can search slavage yards around the country. There are also individual salvage part places on the web that have searchable data bases.
tom johnso
Gardner, Illinois
Thanks for the info. Found a place in California that sells remanufactured units or will rebuild mine. Have to wait for a reply from them this week. I'll post results if this is a viable option.
Repair -Laboratory is the business???
SHOrod
Torrie Tuned
Cedar Rapids, IA
If you do opt to go the used route, you'll need to be able to code the replacement with the correct as-built codes. If you are unable to extract them from the current Hydraulic Control Unit (HCU) before removing it, you'll need to look up the correct codes per your VIN.
-Rod
