the4biddendonut
Hurry up meow.
I have a 93 SHO with an ATX. I was in the middle of changing the valve cover gaskets and doing a tune up when I saw the inside of the intake manifold. It was lined with 2-3mm of carbon build up. I just didn't feel right about installing it with all the carbon in the intake like that, so I dismantled it and had a local machine shop steam clean it for me.
Now I'm ready to put it back together. So my first question is if there are any torque specs for the runners and secondaries of the intake. I keep finding the specs for the twelve 10mm bolts, but can't find any other specs.
Second question is, why can't I see any difference between the 4 intake mounting brackets??? I read that one is supposed to be different where the ground strap bolts to the intake. I lost track of which one goes where because I thought they were all the same when I took it apart.
Thanks.
Thanks.
