1995 SHO ATX squeal noise??????
brandon1186
ontario
i have a 95 sho atx with 241.000 km and i just replaced the flex pipe on the exhaust and now when i floor the car right before the secondaries open i hear a squeal noise and it stays all the way to 7300rpm do you think it might be a exhaust leak? i have changed the speretine belt and most of the pullys it does not make the sound down low any suggestions????
mclarida
Orlando, Fl.
Does the squeaking happen when it is cold...hot...etc.. Also, mine squeaks as well and sometimes goes away if I reverse my belt. I have replaced my belt and all the pulleys. Tensioner you say... is causing the issue.
