1995 OEM Spoiler Hardware
brainDfect
Brownsville, TX
Hello to all. I seem to have misplaced the hardware (screws, washers, grommets, etc.) for installing my OEM spoiler for my '95. Does anybody know what the hardware consists of? My only alternative is to find them separate. I also don't remember what company I bought it from since it was through ebay about 4-5 years ago. Thank you in advance for your help.
O.Hernandez
Brownsville, TX
NoSlo
SHO Owner
Portland, OR
The only thing that holds the spoiler on is 5 nuts with integral washer. They also have a rubber washer/gasket on the underside that falls apart when it get old; it might be good to replace this or seal around the nut with silicone to keep the trunk waterproof. Any nut of the correct threading with a metal washer (built into the nut or seperate) should work fine. Any hardware store should hook you up - just take the spoiler into the store and find the matching nuts from their bins-o-nuts.
OEM = original equipment. I assume you mean that you have the stock spoiler.
