davidb
I just got a 1995 SHO MTX. The radio and CD player worked just fine the first day and then just quit. I put a CD in the bottom CD changer and it worked fine. After work I tried to turn the stock system on and it would not come on. When I push the power button the power antenna tries to go up but comes right back down. The lights on the system work but thats it. I checked the fusses and all seem fine. Does anyone know what could be wrong.
When I push the power botton the antenna tries to go up then comes right back down, nothing else. Someone mentioned that there is an AMP bypass cable already under the dash that is not being used. Is this correct. Can I pluge my stock radio into it? Sure would appreciate more help with this problem.
