ozzake
First off I'm new so I hope this is the right place for this.
I have a 1994 SHO 3.2 auto, its got 150k on it
Within the past few weeks it has gotten very hot and muggy in WI and my car started acting up. When I start it it runs fine like it should and I can drive it anywhere, but once I shut it off and try to restart it I get chaos. The car will start hard, then once it is running the tach will jump sporadically, it misfires terribly, and when you put it in gear it stalls. after an hour of sitting and cooling down it'll start right up again.
I changed the fuel filter and pump (didn't help, although it gained a lot of power)
I bought a code reader and took the codes off, cleared them all and waited to see what came back on, all I get is an EGR code (I'll scan it again today)
I changed the DIS
I'm running out of ideas, the only thing I can think of is it might be the crank position sensor
Any input would be extremely helpful
Thanks
Ozzie
I changed the DIS
Thanks
Ozzie
