1994 ATX Climate control Head Unit
Tigerdadgc
Miamisburg, Ohio
I have a 1994 ATX SHO and one of the hard buttons is broken. I found a unit out of a 1996 towncar but it would not fit. Does anyone have any idea what year group would have the larger soft button units that would fit? I'm going back to the Junkyard to look again!
Mike
hawkeye18
Sorta cares
Norfolk, VA
FYI, you can swap the faces on them; I just did this with a unit out of a Lincoln Mark VIII. You have to take the faceplates off each unit, and swap just the faceplates by desoldering and resoldering the two 8-pin connectors on the boards. Cut the wire to allow it to fit. There's a thread on here entitled, "Yes, you can use ANY eatc!" (verbatim) that describes how to do this.
crystizel
