1993 Ford Taurus SHO
Jpie007
Michigan
I'm helping my brother sell his car. He lives in the East Lansing area. He can't afford gas and car insurance anymore due to the fact that he's a poor college student.
It's a green 1993 ATX Ford Taurus SHO. It has just over 140,000 miles. It comes with a set of steelies he used for winters with tires that have decent tread left. Within the past 2 years or so, it has had a handful of replacements.
:woo-hoo:
Whats New:
Alternator
Battery
Steel Brake Lines
Ball Joints
Brake Pads
Idler Pulley
Starter
Rotors
Totalling at about $2600.
From what he tells me, there are a couple issues with it. I'm not sure what they are exactly though. He says after he drives it for a while, he'll stop at a light, and when he goes to drive again when it turns green, it will hesitate and then kind of launch forward. I'm thinking it might be a brake issue. Also, the last time he drove it, his gas went up and down and when he parked, he could smell gasoline. So there must be a leak somewhere. There's just a little bit of rust but nothing too life threatening.
Make me an offer!
DSC 4596
DSC 4592
DSC 4600
DSC 4601
DSC 4610
DSC 4611
DSC 4612
DSC 4621
DSC 4622
Mark in PDX
Woodburn, Oregon
More information on the '**** from start'.. I emailed them to find out more information, thinking it might be the dreaded failed clutch piston.. Doesn't sound like it from the further description, may be a fuel issue.. Here are the comments, he asked i post for him..
Could you please do that? I can't seeing how I can only make a post on my thread after every 7 days. So I can't for a few more days.
Quote:
Originally Posted by Mark in PDX
The cooling for the tranny depends somewhat on the rest of the engine, if the fluid overheats and gets too thin, it can affect shifting..
If it ONLY does it at low gas and regardless of temperature, might not be tranny... If it only does it 'sometimes' then it is possible he is having a fuel pressure (filter usually) issue or pump issue in the tank.. SInce this is a rustbelt car (IIRC) I'd worry about stuff in the tank and change the filter.
/shrug, I am just guessing based on the little information I have.
Post the rest of this into the group and ask...
Mark
Quote:
Originally Posted by Jpie007
Would it still be the tranny if that only happens when the gas gets below 1/4 of a tank? He has only experienced that a couple times, both during the summer when the gas was low. Other than that it doesn't do it. The first time it happened it turned out that the coolant was low. His dashboard said low coolant so he asked if it was low when he got his oil changed and they said that it was. So do you think that the lack of coolant messed up the tranny???
