I hope its ok to post here, I did not see a forum for the v6... Anyways I hope someone with more experience with a sho can give me some advice, because I do not have alot of money to guess at buying parts.
There first is no engine light coming on... so that to me makes it a guessing game..
What is happening is after driving it for a while the car will just die... then after setting a while it will start back up and drive a while longer then die again.
I thought this was a ignition coil problem cause when it happen i checked to see If i was getting any fire and there was no fire on the spark plug wires
so I replaced the coil... and it started right up after that... but it is doing the same thing again.
I have read where a cranshaft sensor if bad will cause the plug wires not to fire? but what about the camshaft sensor if it also is bad will it keep the plug wires from firing?
and if either one will prevent the car from firing though the plug wires.. if one is not all the way bad will it be able to fire after setting a while and run a while before It dies again?
could really use advice cause these parts are not cheap.
Thank you.
Thank you.
