1993 3.2 mtx
38SHO
#1 Oil Abuser
North Palm Beach
Asking 2000 OBO
car is located in North Palm Beach, FL
if I don't get what I want, well then no sale... I don't need money or anything, so I'm not trying my hardest to get rid of it.... if nobody wants it, I'll fix more things wrong with it and sell it for more later.....
I'll add some pictures later, I need to get more interior pictures and upload them
The Good:
RUST FREE SOUTHERN CAR
3.2 Swap w/ 3.0 cams
new fuel pump(walbro 155lph)/fuel filter
new SHo Source 8lb aluminum Flywheel
new clutchnet clutch disc/pressure plate
new SHOnut Ceramic TOB
new rodshifter bushings
ALSFB's
11.6" brakes w/ Ford OEM pads
new rear brakes
new Moog HD rear swaybar endlinks
new TPR rear swaybar bushings
new TPR front swaybar bushings
20.5mm front, 26mm rear swaybars
Monroe Sensatrac struts
new reman Cardone PS rack
new Moog outer tie rod ends
bigger PS cooler
new radiator
new condenser
new crank sensor
new cam sensor
newer timing belt/seals
rod bearings done
new reman altenator
new belts
Silver/Gold painted intake/valve covers
silicone couplers
Taylor red spark plug wires
new motorcraft spark plugs
new battery
rear strut tower bar from neon-thick aluminum bar, not the regular cheap ebay ones
SHO Source equal length catless y pipe
Borla catback
17"x7.5" Volvo almathea wheels
235-45-17 Pirelli P6 tires
front end bra(has mark on it)
new coolant hoses
TB coolant bypass
Powered by Yamaha ford emblems
remote keyless entry
The bad: this might seem like a lot, but its a decent driving car... just want to be honest with you
I can fix any of this for an additional charge for you, things that require new parts/new tires, I will give to you at my cost. Labor will
either be free or at a very good price
Front seats could be redone
burn hole in rear seat under arm rest
outside left rear door handle doesn't work
lock cylinder in driver door doesn't work
no A/C compressor, no EATC
sunroof visor is off track, needs to be taken apart and put back together correctly, motor works though
no heater
I think needs new Left front hub bearing soon
needs strut rod reciever cup welded on right front
speedometer bounces on gauge most times, except at higher speeds
needs 2 tires soon
dash has a spot where its ripped apart on the side by the passenger air vent about 2 inches long on the corner
carpets seen better days, but same could be said with 95% of SHO's no holes or anything, just dirty
needs new front bumper, hence the bra to cover it up
rear bumper has 3 drip stains running down it
hood has some dented areas
trim underneath windows bubbling
front two windows scratched
headlights foggy
there is probably more in either category, I'll add more if I remeber anything
Thanks......
38SHO
#1 Oil Abuser
North Palm Beach
38SHO
#1 Oil Abuser
North Palm Beach
I'm not totally done with SHO's
just for now
I don't have enough money to support my habbit(SHO)
and I can't just let the SHO sit and drive something else cause I can't afford to buy something else without selling the SHO...... nor do I have a parking spot for it
so this is the only thing I can come up with... sell the SHO for now.... I'd like to get another one at a later date when I can put more effort to it and I don't live in a stupid condo, but tat that point it'd be a 2nd car and not my DD like this one, or find a nice clean 3.2 and swap it into something RWD
Joe_SHO
ND
Is this vehicle still for sale? Could you please take some pictures of the interior? Is there a hole in the dash where there used to be an EATC?
38SHO
#1 Oil Abuser
North Palm Beach
no thats where my radio is half assed, its not perfectly blended in..... but there are holes in the din slots, there is where I was going to put gaugues, but the panels I ordered didn't fit right....
I can take some pictures of the interior
I just claybared the car and put 2 different waxes on it....
I don't really want to sell it, sometimes it just ****** me off... its a 15 year old Taurus... its gonna have problems.... it would help if I already had something else to tinker with....
I'd accept trades or trade/cash in either direction
I'm just really picky with rust cause I always work on my cars so much... if it has even the slightest bit of rust I won't touch it anymore
