1992 Midnight blue MTX
d2freak82
Kansas
I have a midnight blue Ford Taurus SHO in fair to good condition, asking 1600 obo. A/C Blows Very cold, I've just replaced a bunch of O-rings and the canister along with the compressor. I had it vacuumed and charged by Ford. The car runs incredibly well, very dependable. The check engine light comes on after about 10min because the o2 sensor needs changed. This is the only mechanical thing I know of that is wrong with it.
Below is a list of things I have changed on it, the steering/suspension is new all the way around. The headliner has also been recovered.
There is a crack in the windshield that does not effect your visibilty, it's been there since I've owned the car.
The trunk latch broke on the original trunk lid, which I still have, but I had to install a new one and it's green.... it doesn't look too horrible but I wanted to make everyone aware.
The seats have quite a bit of wear, but I'm including seat covers. I just installed a new cd-player that has very little use. The rubber(tires) is new has about 5000ish miles on it. I've done a lot of work to this car, it is a great car. I only drive a mile to work, which I use my truck for.... the wife has her car. We don't need the extra.
New --
Power Steering Rack
Power Steering Pump
A/C compressor
A/C Filter/O-rings
Clutch & Pressure Plate Throw-out bearing
Struts all the way around
Outter Tie-rod ends
Strut Rod Bushings
Stabilizer Bars
Front Brakes
Platinum Plugs & Wires
Transmission Replaced
Front and Rear tires (5,000 miles on 'em tops)
Subframe Bushings
Magnaflow Ypipe (still have original if needed)
The car has approximately 196,000 miles. These motors are known to go strong to 400k with proper maintenance. This car is very fast for what it is, will do a 1/4 mile in under 15.
Alternator Changed from older style to newer 3g for higher output. Have original mounting brackets, and alternator.
It comes with a bunch of spare parts I have collected over my time of owning the car, I have a transmission, wiper motors, dimmer switch, rim and other misc items.
Dash has a crack or 2 in it, but nothing to terrible looking, I think it's pretty normal. Vents aren't in the greatest shape, but with a little patience they can be moved where you want em :dribble:
I am willing to meet up with someone to exchange the car if needed.
Sell2
Sell1
Box
vortex2450
Buying Parts...
North Carolina
NIce car. More pictures would help with your sale. A walk
around video is even better.
GLWS
-Josh
